code 172/175
-cold air intake
-ATTEMPT #2-WHY DID YOU REPLACE THE FUEL PUMP;what were you trying to fix by replacing the pump. did you install a flex fuel compatible pump in the vehicle
if the flex fuel sensor is askew, the vehicle will run rich; do a vin check in the tool section of this site
