Uplander 2005-2009
Platform: U-Body
uplander 2007 iac location
Old Jun 12, 2017 | 10:04 PM
uplander2007's Avatar
Default uplander 2007 iac location
Hi,
Can somebody locate for me the iac.
I am trying to troubleshoot rough idle..thanks!
Neo
Old Jun 12, 2017 | 11:21 PM
if its drive by wire (no throttle cable) it does not use an iac motor. idle is controlled by the electronic throttle motor
Old Jun 13, 2017 | 1:53 PM
Papa Bear's Avatar
How many miles on the van? Is the CEL on?
Have you cleaned the throttle-body?
Are the spark plugs and wires original?
Are there any codes stored?
Does it idle rough in gear and in neutral?
Old Jun 13, 2017 | 2:55 PM
Smile
Thanks for the info, Tech2...I already tried cleaning the TPS, but it still the same...anyhow.. I have a check engine light. I'll give an update as soon as i get an obd2 reader...
Old Jun 13, 2017 | 3:06 PM
Papa Bear,
The van got 160K+ already...Yes the CEL is on..
The spark wires and pugs are replaced already... the TPS was cleaned...and still rough idling.If I press the pedal to the floor while I turn on the ignition key, there is ignition but will not continue when you release the pedal. But when no foot on the pedal and ignition is started it will continue and but it's idling rough.
thanks,
Old Jun 13, 2017 | 3:17 PM
Papa Bear's Avatar
I'm saying clean the throttle body - not the TPS
Like this
Old Jun 14, 2017 | 9:46 AM
Like this https://www.youtube.com/watch?v=zUV4nXc-pXU
That's what I mean - the throttle body. That's what I did, but to no avail...
