Uplander 2005-2009
Platform: U-Body
evap code on 2006 Uplander.
Old May 23rd, 2024, 2:45 PM
boomer7179's Avatar
Default evap code on 2006 Uplander.
I have a 2006 Uplander 3.5 liter, I recently had the check engine light to come on. I got it checked at Oreilly's and they said it was a evap code but didn't say what number. I have noticed that the van starts right up when cold but after warming up and I try to restart that it turns over and over and over before finally starting. Starts great cold but not so good when warmed up. Could the emission vapor canister purge valve solenoid on the engine that the vaccume goes to be causing this? I have looked on YouTube and that part seems to be a possible cause. Would the emission vapor cannister purge valve solenoid cause an evap code? Thanks for any help.
Old May 23rd, 2024, 3:32 PM
the number is important. Go back and get it. Otherwise you could be hunting for days and wasting money.
Old May 23rd, 2024, 4:53 PM
boomer7179's Avatar
It's over a 40 mile trip and with the weather today bad here in Kentucky, I thought I would call them. The guy said that he wasn't certain but thinks it was P0496 code but could have been P0449, but he believes it was P0496. It did say evap tho, that he knowed for sure. Thanks
Old May 23rd, 2024, 5:41 PM
the evap system has many parts, including plumbing and electrical, so you want to be certain. Code readers are pretty cheap these days.
Anyway here are some diagnosing steps for the codes he thinks it might be.
I would start with a smoke test for leaks, and then checking the valves for correct operation.
https://www.obd-codes.com/p0496
https://www.obd-codes.com/p0449
CB2003Suburban
May 25th, 2023 8:06 AM
ubZ71
Uplander
12
August 4th, 2017 10:34 AM
GHOST169
April 24th, 2017 2:12 AM
chevygirl47
May 10th, 2012 7:50 PM
jengates
Uplander
May 1st, 2012 5:48 AM
Quick Reply: evap code on 2006 Uplander.
