Uplander 2005-2009
Platform: U-Body
flickering lights
Old May 21, 2012 | 6:49 PM
bartole03's Avatar
Default flickering lights
hey people im new here trying to learn as much as possible about the uplanders and their problems. Is the regulator replacement a recall,as well as the level /sender in the fuel tank? or is that out of my own pocket? thanks.
Old May 21, 2012 | 7:25 PM
Papa Bear's Avatar
What's wrong with the fuel tank sender?
All the Uplanders "flicker"... I got used to it.
All the best.
P.B.
Old May 21, 2012 | 8:14 PM
bartole03's Avatar
Default flicker
the fuel gauge does not read properly at all, thats why i was wondering why if they were recalls or just usual issues with the uplanders, thanks papa bear
Old May 21, 2012 | 8:44 PM
bartole03's Avatar
Default flickering
have you ever had an issue with engine fans not working at all?
Old May 22, 2012 | 5:53 AM
dejsanders's Avatar
I had that problem... it was an electrial 'switch' of some kind.
I'll check the EXACT fix and reply again.
Old May 22, 2012 | 6:42 AM
johntaps's Avatar
Former Sponsor
Post flickering
There are many possibilities with engine fan not working. First of all check the cooling fan relay and replace it if not working properly. Then check the coolant temperature sensor. I have read in many forums that the 2005 Chevrolet Uplander Engine Cooling Fan Motor is the main reason behind the fan not working. Some of them are the only reason behind engine fan not working.
Old May 22, 2012 | 7:23 AM
Papa Bear's Avatar
Does the van overheat ??
Old May 22, 2012 | 12:45 PM
bartole03's Avatar
hi and no the van does not over heat, moves over to the mark after half and then backs off (when idiling) stat opening up. otherwise its ohk
Old Jun 2, 2012 | 12:15 AM
bartole03's Avatar
did u find out what the switch was?
Old Jun 2, 2012 | 7:32 AM
Papa Bear's Avatar
I asked "What's wrong with the fuel tank sender?" and you replied .....
That does not answer the question, you just gave me a vague response.
What do you mean by "does not read properly at all" ?
A google of "Uplander TSB" or "Chev Uplander service bulletins" etc usually yields a great deal of info.
All the best.
P.B.
