Uplander 2005-2009
Platform: U-Body
Need help with issue after getting snow stuck
Old Jan 27, 2016 | 3:45 PM
Bobby Parker Jr.'s Avatar
Default Need help with issue after getting snow stuck
Hi
I have an 2008 uplander which nothing was wrong with it at all till I got stuck in the snow in my front yard the right front tire was buried in snow and dirt
After I got it out I notice the speedometer, cruise control didn't work and at times it was not shifting right (not all the time)
I drove the canon the highway and at 2 points the speedometer tried to work for like a mile but ended up going back to 0
Now I took it to a auto shop (not transmission shop) and they said the transmission needs to be replaced but this van worked fine till I got stuck in the yard, I disconnected the battery to reset it, did a gauge test and they work
And pulled the. Trans sol,ECU and Ign relays to try a hard reset still same issue
Anyone can help me here this is my work van without it I can't. Work
Old Jan 27, 2016 | 4:40 PM
Papa Bear's Avatar
Is the ABS light on?
Old Jan 27, 2016 | 5:28 PM
No it's not, no lights are on and the traction control still works
Old Jan 27, 2016 | 6:46 PM
try another shop
I question the vehicle speed sensor as this input to the tcm is sent to the cluster for the speedo to work. without the vss signal, the trans won't shift properly. this should set a dtc and illuminate the cel.
Old Jan 27, 2016 | 7:04 PM
Originally Posted by tech2
try another shop
The shop said they tried another one with no change snd that it looked like that some thing hit the bottom of the new sensor so they felt
That something is wrong in the trans to do this. I got no clue on what they are talking about
Old Jan 27, 2016 | 7:21 PM
so it sounds like they confirmed the vss signal is out. I suspect the connector or wiring may be damaged. the wiring needs to be ohm checked. it would be pretty hard to damage the reluctor gear on the output shaft in the transmission case...the sensor and wiring connector on the other hand are pretty exposed. imo try the tranny shop for a second opinion before replacing a transmission.
Old Jan 27, 2016 | 7:55 PM
How hard is it to replace the wiring to it is it plug in or wired in. Guess I am asking is it something I can do myself
