Uplander 2005-2009
Platform: U-Body
Problem: pass brake light on while car is off
Old Mar 4, 2008 | 9:26 PM
jpuplander's Avatar
Default Problem: pass brake light on while car is off
My wifes 05 uplander is off, no key in ignition, parked in garage and has the passenger turn signal/brake light(middle bulb) remains on. when I turn the car on and cycle the turn signals they work as normal, no fast turn indication on the pass side.
I pulled all fuses on the pass side block, as well as the underhood block, the light went out when the main power to each fuse block was pulled.
I replaced the bulb and it remained on.
Any suggestions of what to do next?
where is the turn signal relay, I cannot find it in the fuse blocks, is it under the dash?
I am in michigan, could salt, or temp change affect this?
I just replaced the drivers side wheel brg at 58k miles, not to bad a job.
Jp
CarpAZ87
Jul 9, 2015 10:14 AM
beckya99
Jul 12, 2011 12:29 PM
seandw
May 16, 2011 1:17 AM
wally123
Dec 4, 2006 10:50 PM
