Uplander 2005-2009
Platform: U-Body
Rattle
Old May 14, 2010 | 12:42 PM
dieselscout80's Avatar
Default Rattle
We've had a rattle in the van since we got it on thius last oil change I went looking for it. I found that the rear AC lines were loose. I added some old hose to keep them quiet and in the very back there is a clamp that was missing a nut. The rattle is gone now.
Old May 14, 2010 | 5:59 PM
Papa Bear's Avatar
Good to know. Thanks for the info. !!
Old May 15, 2010 | 6:51 AM
capucine's Avatar
Anothe issue with cable rubbing. The other day when I was spraying some rust check underneath between the frame members I found that the parking brake cable that run under from the brake pedal is rubbing on a frame hole opening underneath. Everytime you use the parking pedal the cable move a little bit and where it touch that opening the side of this hole are sharp. This can lead to wearing of the cable plastic liner on a long run. I installed a piece of rubber hose over the cable where there is a contact with that opening.
JustinL
Aug 23, 2014 12:54 PM
dabbjb
Uplander
Mar 8, 2011 6:38 PM
kc01976
May 17, 2007 5:53 PM
duffeldoffer
Oct 30, 2006 1:36 AM
elcaminomike
Chevelle & El Camino
Mar 11, 2006 10:12 PM
