Uplander 2005-2009
Platform: U-Body
rear right turn signal / brake light always on, even when car is off
Old Apr 13, 2019 | 6:06 PM
Frederic Theriault's Avatar
Default rear right turn signal / brake light always on, even when car is off
I have a 2008 uplander, I have full permanent Voltage coming out of the bcm on the pin leading to right rear turn signal / brake light and same trailer wire.
It's the dark green wire. It shows full voltage even when the car is turned off.
Is the bcm shorted / needs replacement?
Old Apr 13, 2019 | 9:45 PM
find the brake pedal position switch on the brake pedal...unplug the connector...if the brake lights go off...try a new switch.
Old Apr 14, 2019 | 1:08 PM
Light still stays on..
Old Apr 14, 2019 | 5:02 PM
maybe the bcm is bad or maybe the wire is shorted to voltage.
the bcm will have full diagnostics for that circuit...have the bcm checked for fault codes. a full function scan tool that can access body codes is required...code reader won't do it.
Old Apr 15, 2019 | 8:49 PM
Papa Bear's Avatar
Hello tech2:
Would you send me a PM, I'd like to talk to you if I could.
Thanks.
Bob
