Uplander 2005-2009
Platform: U-Body
Remote not working on automatic doors
Old Jul 3, 2008 | 2:25 PM
pkcsdam's Avatar
Default Remote not working on automatic doors
I have a 2005 and my remote recently started acting up when I try to open the passenger side door. It works after I press the button several times and if I'm close to the door. I can use the switches inside to work both doors and the driver's side is fine with the remote, so I don't think it's an issue with the battery. Does annyone know where the sensor is located to make the remote work? Possibility it's dirty or blocked partially?? It's an $80minimum charge just to take it in then the charges to fix it. Any help is appreciated.
Old Aug 12, 2008 | 11:04 PM
tcmckay's Avatar
Default RE: Remote not working on automatic doors
I have a remote that was not working as well. I opened the remote and found that some of the electronics inside had been dislodged. Once I soldered them back in place everything worked ok.
57chevythunder
Sep 9, 2015 1:20 AM
tom7254
Aug 8, 2014 8:35 AM
kshanok
Dec 14, 2013 5:15 PM
cyr0n3
Sep 29, 2011 3:43 PM
G-Force
Jul 20, 2009 3:18 PM
