Uplander 2005-2009
Platform: U-Body
Testing fuel pressure - P0172, P1174
Old Sep 3, 2019 | 7:14 PM
FarmerBob's Avatar
Default Testing fuel pressure - P0172, P1174
I have a 2008 Uplander with 3.9L engine. I have a couple of codes coming on, they come back after a short drive after resetting them, usually P0172 and P1174 together, sometimes one or the other.
I started by cleaning MAF sensor with no change. I then tested fuel pressure at the rail, I got 60 psi with key on but engine off, and 67 psi with engine running at an idle. This seems a little high, the correct operating range I found was 59-62 psi. I was going to test the fuel pressure regulator but this engine doesn't have a vacuum controlled regulator on the rail. There is an electronic component on the end of the rail but I don't know if it's a pressure regulator, some research suggests it might be internal in the fuel tank or built into the pump.
Is 67psi at an idle too high? Does this engine have a regulator I can test?
Next steps I was thinking about Ohm testing the injectors. Also wondering if there is a way to test the EVAP purge valve/canister.
Thanks for the help!
Old Sep 3, 2019 | 9:37 PM
the pressure does seem high...I believe the ppump pressure is pulse width modulated by the pcm .
flex fuel vehicle? is yes, check the flex fuel %. if more than 10% and you are not using flex fuel...reset the flex fuel sensor. if the code returns I would take a guess and replace both precat o2 sensors.
Old Sep 4, 2019 | 10:55 PM
FarmerBob's Avatar
Thanks for the quick reply. The vehicle is flex fuel, I do use E85 when the price makes sense to run it, but haven't used it for the last few tanks. My scan tool didn't show me alcohol %, but I borrowed a friend's scan tool that would read this, and it was at 16%. This tool didn't allow me to reset this value. 16% seems realistic, as I could have had some E85 mixed in still.
I forgot to mention that I had already replaced the precat o2 sensor with no change.
I'm thinking about Ohm testing injectors next. Other ideas where to go next?
Thanks again
Old Sep 4, 2019 | 11:38 PM
reset the oh content...find a way. if the sensor readings are askew...it will run rich on both banks.
Old Sep 7, 2019 | 3:08 PM
FarmerBob's Avatar
I'll try resetting the alcohol content next week, have to find a shop to do it for me. 16% seems realistic so I'm not sure that is my problem, so I thought I would go ahead and test the injectors today.
The 6 injectors test anywhere from 12.4 to 12.7 ohms. Is this close enough or would 0.3 ohm difference potentially be a problem? I can't find a range for what they should be.
Also, this 3900 engine only has 1 pre-cat O2 sensor, so the P0172 code doesn't help me narrow down between front and rear bank.
Old Sep 7, 2019 | 6:13 PM
maf cleaning never works. if the reset doesn't work replace it.
if the injectors ohm readings are all close to the same; electrically they are probably fine...doesn't mean they are flowing the same. GM injectors are pretty good...rarely have I seen a problem with them. without a injector leak down tester or the gm specialty active fuel injector tester...all you can do is pull the rail and check for leaks or bad spray pattern....something I would do last.
lkaras99
Sep 15, 2020 3:16 PM
tonyfalcon
Aug 19, 2019 2:11 PM
rmoore45
Feb 13, 2015 1:35 PM
mattysgarage
Mar 23, 2012 4:00 PM
mediaman67
Apr 7, 2010 6:17 PM
