Turn signal works except when lights are on?
I have a Chevy uplander 2007, the front passenger turn signal won't work if the lights or parking lights are on but if the lights are off the turn signal works
while you in there checking the bulb, check for power at the connector. Its a 2 filament bulb.
the brown wire feeds battery voltage to the park lights, the blue/white wire should have battery voltage for the turn signal.
