Uplander 2005-2009
Platform: U-Body
Uplander "Reduced Engine Power"
Old May 23, 2024 | 6:49 AM
  #21
limpy's Avatar
I see that you have the message "starting disabled" Did you take the chip from the old key and install it in the new key?
Old Nov 16, 2025 | 2:10 AM
  #22
Kyler623's Avatar
Originally Posted by limpy
been there,long story ,short answer,transmission solenoid was sticking,found this after replacing throttle body,gas pedal and hours of checking continuity on related connections between pedal,throttle body and ECM.Nightmare condition!!DTC'S were P1125,P2125 and P2138. I hope this helps,FYI replacing this transmission solenoid is a major job,not one for the average backyard mekanik(which I am proud to be) I found that when I was able to drive normal(my problem was intermittent) I kicked it into passing gear and resumed normal driving,by doing this several times it started to get better,I also would accelerate faster than normal each time I drove my 2006 Chevy Uplander and eventually it kept getting better and finally stayed out of the "DREADED LIMP MODE" I hope this helps you
When engaging passing gear, was it a hard shift or slip? Did the transmission fan stay on long after shutting off but no overheating? Your situation sounds a lot like what I'm going through? How long did it take to unstick the solenoid? Thanks in advance!
cdelta1975
Dec 4, 2019 12:56 AM
2006 Chevy Impala
Apr 25, 2018 6:52 PM
Rkn
Jun 15, 2015 11:32 PM
