Venture 1997-2005
Platform: U-Body
1997 Venture horn
Old Aug 3, 2007 | 6:51 AM
rceyba's Avatar
Default 1997 Venture horn
Does anyone know where the horn is for a 97 Venture? Mine has been sounding weak lately, and I recall that there may actually be two horns for different tones. Either way, I need to replace it because it keeps shorting out and I have to replace the fuse almost every day.
Thank you.
Old Aug 6, 2007 | 6:45 PM
nprdavid's Avatar
Default RE: 1997 Venture horn
it is behind the headlight housing, right or left side depending on year. just honk the horn and listen to what side it is on and that will let you know.
Old Aug 7, 2007 | 9:59 AM
rceyba's Avatar
Thanks!
So, if I take out the headlight housing, I should be able to get to the horn easily?
Rick
Old Aug 8, 2007 | 8:40 AM
nprdavid's Avatar
you got it
Old Aug 8, 2007 | 9:43 AM
rceyba's Avatar
Thanks again! I really appreciate your feedback.
Rick
Old Aug 19, 2007 | 8:07 PM
nprdavid's Avatar
no problem
Old Mar 29, 2008 | 3:10 PM
rjnewt's Avatar
My 1998 Venture has aproblem with the horn also. It will work for a bit and then blow a fuse.
Why do you think that replacing the horn will solve your problem?
sheriff13
Mar 25, 2008 12:55 PM
sheriff13
Mar 25, 2008 12:44 PM
isaac_22
Dec 26, 2007 9:23 PM
ezwind72
Mar 30, 2007 2:02 PM
zulu
Mar 28, 2007 4:58 AM
