Venture 1997-2005
Platform: U-Body
1999 3.4L surging at idle
Old Mar 4, 2010 | 3:23 PM
drdeboer's Avatar
Default 1999 3.4L surging at idle
After reinstalling the plenum and etc after correcting a heater hose leak, I have a surging at idle condition. I replaced the fuel filter and drove the vehicle around and I cannot get this resolved. I feel if I could just increase the idle speed just a hair it would dissipate, but the idle speed is set by the icm. Any suggestions would be appreciated, Thank You.
Old Mar 4, 2010 | 6:23 PM
maxxman04's Avatar
pull and clean the idle air control valve, and maybe the egr valve too.
Old Mar 13, 2010 | 12:22 PM
Rogers mechanical repair service's Avatar
I ran into this before and it was the TPS throught position sensor @ $24 and a Allen wrench should fix it. Also a weak ignition coil will cause the engine to try to compensate. Pull plugs to see if one or more plugs are not burning right. Then trace that plug wire to the pack to replace.
xjohndoe001x
Aug 3, 2013 2:44 AM
S10bd
Apr 28, 2010 11:16 AM
barrypyoung
Apr 16, 2008 6:46 AM
kan_man69
May 2, 2006 10:30 AM
aberg7039
Mar 30, 2005 12:42 PM
