Venture 1997-2005
Platform: U-Body
2000 Venture LS - Power Sliding Door "Reset"
Old Sep 11, 2009 | 6:17 PM
CKFords's Avatar
Default 2000 Venture LS - Power Sliding Door "Reset"
I bought this van a couple of months ago. The power sliding door (PSD) didn't work. I then got a manual and realized that the PSD override switch was ON, meaning the PSD was OFF. I turned the override OFF and the PSD worked...sort of. It only worked when you opened the door from the outside. It would close via the overhead and door frame switches and the remote, but it would only power open from the outside door handle. Well, now it doesn't work at all. I tried the PSD RESET feature as stated in the manual a few times, nothing. (Is there a mistake or missed step in the manual, it isn't very detailed). I actually had it working once for a moment, then it quit again. By WORKING, I mean as stated earlier, semi-working. At any rate, I checked all of the related fuses and the 30A circuit breaker, of course all of that is good or it never would have worked at all. Does anyone have any experience with PSD problems such as mine and not just the "Do the RESET thing as in the manual" or "could be a blown fuse" stuff? None of that seems to apply here. Also, the power lock on the PSD is intermittent as well. I am wondering if there is a near-short or possible contact issue. I tried contact cleaner on the PSD electrical contacts, no help. As of now, the PSD does not work at all and all related fuses and the 30A circuit breaker is good. Sorry for the novel, I just wanted to give as much info as possible. Great van other than this. Thank you.
Old Sep 13, 2009 | 10:12 PM
CKFords's Avatar
Hmmm...kinda quiet in these parts.
Old Oct 3, 2009 | 4:01 PM
sekeraksm's Avatar
My 01 does that from time to time. I get it working by manually closing the door all the way then manually opening it all the way then back to close. Everytime ive done it it started working properly.
Old Jan 7, 2010 | 12:12 PM
jper1222's Avatar
Having similar problem, I would like to disconnect the door and use it manually, tired of climbing over seats and getting locked out of the sliding door....help!!!!!!!
Old Jan 7, 2010 | 12:39 PM
jper1222's Avatar
Default Venture 2000 sliding door
Thanks, do you know how to reset the door or put it on manual?
Old Jul 6, 2013 | 8:05 AM
rszkutak's Avatar
Still no solutions, huh? I have same problem with my 2003 Venture.
reelcharacter
Dec 6, 2016 11:11 AM
knarly gto
Jul 6, 2013 8:00 AM
MegaMiles
Aug 12, 2010 10:15 PM
DonK
May 26, 2010 4:37 PM
Bo Okeefe
Jul 6, 2009 9:02 AM
