Venture 1997-2005
Platform: U-Body
2002 Venture AWD Rear Coil springs, Which one?
Old Jan 6, 2014 | 12:53 PM
ebaman's Avatar
Default 2002 Venture AWD Rear Coil springs, Which one?
I need to replace the rear coil springs on my 02-Venture-AWD Long Wheelbase.
However looking in to some parts dealers, there seems to bee an endless list of springs, with various codes.
For what I think, after decoding the parts-label, I should have:
FE4 6655 P SSP M SUSPENSION SYSTEM SPECIAL RIDE & HANDLING
YD6 31245 P SPRING RR, BASE EQUIPMENT
6HU 41745 P FLH M COMPONENT FRT LH COMPUTER SEL SUSP (6HU)
7HU 43041 P FRH M COMPONENT FRT RH COMPUTER SEL SUSP (7HU)
8NN 44546 P RLH M COMPONENT RR LH COMPUTER SEL SUSP (8NN)
9NN 45842 P RRH M COMPONENT RR RH COMPUTER SEL SUSP (9NN)
Now, I have found something that I interpret as correct:
Code:
SPRING. Rear. Rear Spring.
SPRING,RR(CODE NNN). Required: 02
For: B SUSP(8NN),(9NN) (2002-2007) (2002 - 2006).
For: U122(16) SPECIAL SUSP(FE4),SUSP(8NN),(9NN) (2005-2006) (2005 - 2006).
For: UT SUSP(8NN),(9NN) (2002-2004) (2002 - 2004).
For: UT SUSP(8NN),(9NN) (2002-2005) (2002 - 2005).
For: X122(16) PERF & HANDLING SUSP(FE5),SUSP(8NN),(9NN) (2005-2006) (2005 - 2006).
However, I'm not quite sure about it.
And by the way, can you recommend any on-line dealers in US that will sell to Sweden?
Here the springs seems to be made of gold with diamond inserts.
Attached Thumbnails 2002 Venture AWD Rear Coil springs, Which one?-wp_20140106_17_02_53_pro.jpg
Old Jan 9, 2014 | 7:58 AM
200OZ's Avatar
I checked with a friend of mine at a local Chevy dealership, and got the GM part # for you. It is #10306378. This should help you cross reference part #'s to other manufacturers. Try Rock Auto, they ship world wide.
RockAuto Parts Catalog
I tried looking up the spring for your Venture, but came up empty, but crossed to some different years, that had matching GM part #'s, it looks like you can use either of these part #'s below: I got them looking up a 2006 Chevy Uplander, the replacement model to the Venture. The Uplander uses the same platform as the older Venture.
ACDELCO Part # 45H2129
RAYBESTOS Part # 5891129
Good luck,
Mike
Old Jan 11, 2014 | 5:25 AM
ebaman's Avatar
Thanks for the reply, that number corresponds to the one I posted above, so obviously that one should be the correct one.
RockAuto didn't have any, unfortunately.
I've found the springs at a company called Nalley, parts.nalleygmc.com
They charge for what I can see just below $100:- each totaling $200:- + transportation/postage. (and customs+VAT here in Sweden), still a good price compared to what I have to pay here though ($500:- each)
Old Jan 11, 2014 | 12:55 PM
200OZ's Avatar
Good luck, the Nalley sight is pretty helpful. What about the part #'s from the later vans, '05-'07 they use the same springs on some models. Some GM #'s are different just because they are made at a different plant/supplier, no differences.
Mike
silverado 1500 2001
Sep 3, 2014 1:03 PM
vendrasco85
Feb 10, 2014 5:21 PM
