98 Electrical issues???
When my right turn signal is on the clock flashes and sometimes goes off all together. Now it is happening with the left turn signal as well. Also, sometimes the right and left indicators come on faintly when I press on the brake.
Since 3 months ego my van started to do weird thing, like the windshield blades moves up when I turn them off and never comeback to the resting position inside the hud, the upper display with mpg, temperature , etc.. went off suddenly, I checked the fuse and is OK, the display on the radio console is flashing when I push the break pedal, the turning lights goes slower than usual and stop flashing when I push the breaks, the turning light (both at the same time no matter what side is on) on the dash turn solid when I push the break, now I lost the tail lights, but if I turn the hazard on the red (stop) lights start to flash, including the 3rd stop light, but not the orange or with light, the back turning lights are not working in any momentas well the reverse with light.
WOW! im not really the person to talk to about electrical problems you guys. knowing that i just bought a venture. I know nothing about them it seems like you guys are having some ground or relay problems Maybe one of the Chevy Techs Can give you guys a hand
Should i of bought a Venture? good question should of done more research
