Venture 1997-2005
Platform: U-Body
99 Cooling fans not coming on
Old Aug 8, 2011 | 9:57 PM
mattro's Avatar
Default 99 Cooling fans not coming on
I have a 99 venture. The cooling fans will not come on to cool things if I am not running the AC. Running the AC turns the fans on, both low and high. Without AC, I have seen the gauge go as high as 3/4 to 7/8 on the temp gauge, which according to a gauge which puts the temp between approx 240 and 247. That is as high as I have let it get. I have red at other sites that the cooling fans will come on when it gets to 'red' on the gauge but I feel they should come on sooner and don't want to risk damage.
I have tested the relays with multimeter after energizing them and they appear to engage properly with little resistance on the closed circuit (not sure I have a good meter to test the resistance amount, but they do have a closed circuit). I have noticed the relays can be placed in any orientaion so I am not sure it that is a problem.
The temp was running dead cold at interstate speeds so I replaced the thermostat (not an easy job) and that solved the problem. I have also replaced the temp sensor next to the thermostat.
Does anyone have any idea what to check next?
Old Aug 9, 2011 | 7:54 AM
kevinkpk's Avatar
Jumper across the temp sensor with key on if the fan turns on the sensor is bad.
Old Aug 12, 2011 | 6:43 AM
mattro's Avatar
I already replaced the temp sensor which did not help.
Old Aug 13, 2011 | 10:07 AM
Lrayvick's Avatar
Default Manual Bypass
A trick we use on old motorcycles is a toggle switch to manually turn the fans on. Some guys don't want to depend on the thermo-switch or are too cheap to replace a bad one.
Regardless Kevinkpk's idea of jumpering across the fanstat is a good one. Maybe your replacement is bad too.
Other possibilities are your temp sending unit or temp guage are bad.
slinkeril
Jul 29, 2014 10:03 PM
Eggie329
Aug 11, 2011 11:56 PM
Silverado02
Dec 8, 2008 12:28 PM
SilveradoLS02
Aug 12, 2008 8:45 PM
