Venture 1997-2005
Platform: U-Body
Brake pedal switch wiring?
Old Jun 30, 2009 | 6:44 PM
awp1965's Avatar
Default Brake pedal switch wiring?
I'm installing an electric brake controller for towing and I/m having a hard time figuring out which wire to splice into for the 12VDC signal off the brake pedal switches to the brake controller. There are 2 switches on the brake pedal. Upper switch has 1 wire harness on it and the lower switch has 2 wire harnesses on it. I've checked the upper switch and both wires always have 12VDC on them regardless of brake pedal position. I can't really get on the lower switch because the harnesses are pointing in the wrong direction.
Upper switch has 1 harness with 2 wires (brown and pink)
Lower switch first harness has 2 wires (white and orange)
Lower switch second harness has 4 wires (pink, green/white stripe, pink, violet)
Does anone have a wiring diagram of this and could let me know which wire only has 12VDC on it when brake pedal is depressed?
Thanks.
Old Jun 30, 2009 | 9:11 PM
shawnvw's Avatar
Banned
The orange wire is B+, and the white wire is your brake signal.
Old Jul 22, 2009 | 9:20 AM
awp1965's Avatar
Thanks so much. Once I removed some electrical tape from the white wire I found it already stripped and another wire soldered to it for my remote starter.
oldtruckgoodtruck
Aug 21, 2016 9:04 PM
j86bud
Feb 3, 2014 5:16 PM
mroymalibu
Apr 21, 2009 10:51 PM
SuperTexan
Nov 4, 2008 11:24 PM
junL
Mar 14, 2008 7:42 PM
