The Brakes... again a problem.
The brake pedal in my 2001 Chevy Venture was hitting the floor when I tried to brake.
Changed the master cylinder, changed the calipers, changed the wheel cylinders. Got it bled at a GM Goodwrench garage because I know that you need to have an ABS scan tool purge the ABS module.
I got it back and it was still a little spongy. I thought it was cause my brakes were low, so I changed the front pads and rotors. The brakes are STILL spongy. With the ABS module bled and no sign of bubbles in the brake system, what else could it make my brakes still spongy?
Thanks ahead of time.
![Confused](https://chevroletforum.com/forum/images/smilies/confused.gif)
Last edited by halfasemitone; December 2nd, 2009 at 10:41 PM. Reason: forgot to put the year and model of the vehicle.
Mille Racer 69
December 8th, 2010 8:26 PM
98Silverado621
July 11th, 2009 9:02 PM
