Venture 1997-2005
Platform: U-Body
clunking noise
Old Feb 14, 2012 | 7:44 PM
JoseC's Avatar
Default clunking noise
My Venture makes a clunking noise when passing on holes or anything that sits about 2-3 inches below the road grade. I have noticed the same noise on other Ventures and Montanas. Any ideas? What could it be?
Thanks in advance,
Old Feb 15, 2012 | 4:34 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> JoseC,
It can be difficult to say what may be causing the noise over the internet. If you are concerned about it, I would suggest taking the vehicle in to be inspected by a certified technician. A technician should be able to offer a more accurate diagnosis after a physical inspection.
Please keep us posted.
If you have additional questions, please feel free to contact me.
Louis
GM Customer Service
Old Feb 16, 2012 | 10:28 AM
JoseC's Avatar
Louis
GM Customer Service
Hi Louis
Thanks for your reply. This noise is going on for years... In 2006 I took the car to the dealer where I got it and they found no issue. Few years later I took to an indy shop and they also found no issues. I don't have how to lift the car, so I cannot try to find the noise source myself, so I decided to ask here to see if someone else had the same problem. The fact is that I have heard the same noise coming from other Ventures and Uplanders on the street. It seems to me this might be a common issue.
Old Feb 26, 2012 | 12:16 AM
mos19790's Avatar
i think i had the same problem , i replaced the rear axle " one piece bar " , they call it axle but i call it cross member , they have two bushings right and left where you can see'em right in front of each tire under body " towards engine " , they're cheap like $25 bushings from the dealer and you can't do'em your self unless you have compressing tools to do so , because that's a very common problem for ventures and uplanders too
try that and good luck
Old Feb 26, 2012 | 12:05 PM
JoseC's Avatar
Thanks mos19790. I will check how the bushings look and replace them.
Old Feb 27, 2012 | 7:14 PM
mos19790's Avatar
you are welcome , let me know what happened with your vehicle after you fix it , and i also replaced the stabilizer bar which is located above the rear cross member , u can see it if you crawl down the car and look up it goes across from side to side with also 2 bushings at each side and its like $70 from the dealer " whole thing " , i got those item from the dealer because they cost more at the junk yard , good luck
mojo
Mar 10, 2013 6:42 AM
Mike Sigmond
23
Sep 22, 2009 5:18 PM
peterpiepr
Sep 12, 2008 10:04 PM
Courtzilla
Mar 19, 2008 6:08 PM
dzonen
Feb 15, 2007 11:13 AM
