Venture 1997-2005
Platform: U-Body
engine backfire
Old Oct 14, 2008 | 6:30 AM
cbr600rrnut's Avatar
Default engine backfire
GA_googleFillSlot("Forums_ROS_300x250_noad");
Hi gang
So over the last while after runnning at highway speeds 110-130kph for approx 50kms I would pull off the highway and after sitting at a red light the engine would hesitate and pop (backfire) for about 2-3 seconds and then clean up and run normal. Sometimes the cel would come on only if I run speeds over 120kph and then goes off approx 100km later. Scan code P0101. Now this morning I was driving to work at 110kph and the engine lost power and will backfire if I step on the accelerator to increase speed. Now if I step down hard to engage the downshift the engine will accelerate normally. I am thinking possibly a plugges cataletic converter? MAF? Any thoughts?
Thanks in advance
Old Oct 17, 2008 | 12:00 PM
mjs182004's Avatar
Default RE: engine backfire
what is the code p0101? it may just be an 02 sensor
Old Oct 23, 2008 | 1:19 PM
Cleaned the MAF sensor and all is well...so far.
QBert
May 5, 2021 10:00 PM
firecap
May 11, 2009 12:36 PM
justchilln1424
Nov 7, 2008 1:42 PM
rustedduck
Oct 3, 2008 10:45 AM
