fixed my horn - screwed up something else
2002 Venture
This all started with my horn not working. I checked the fuse etc. but that didn't seem to be the problem and if I removed the horn and connected +- to it it worked.
So rather than messing around with the steering wheel and air-bag etc. I just wanted a working horn so I rigged up a couple of wires to run from under the hood to a switch under the dash that if I press will now sound one of the horns ( I cut it's connector and put one to ground with the other running through my switch to +).
I realize not an elegant solution but I figured I just wanted a working horn.
So now I have a new problem which is the van won't start. I turn the key on and the dash lights come on etc. but if I turn the key further to try and start it I get 'nothing'.
I'm going to go check the fuses I guess...
Update: If I check a little closer today I realize I have no radio either and I think I may have just drained my battery somehow with my 'farmer fix'. So I'm charging my battery and we'll see where that gets me later in the day.
MD
MD
I could be wrong, but...
The horn circuit is incorporated into the ignition.
Its a anti-theft feature. Often theifs will disable the horn, which disable the audible portion of the factory alarm, then hotwire the vehicle and drive away. Incorporating the horn with the ignition switch will cause the ignition to be disabled when the horn wires are cut.
If thats the case, which I think it is, then you would have been much better off to open the wheel and fix it.
Its always best to do it right
Interesting...
If that's the case then I'm be in over my head as I didn't want to have some air bag blow up in my face just to get my horn working.
I'm just going to leave it disconnected from my switch for now as it did start again after I put the charger on then maybe I'll remove my stuff and get a mechanic to look at it.
Thanks.
Thanks.
bamafutbal
November 3rd, 2012 7:59 AM
SILVERAD01
April 10th, 2010 3:35 AM
Suthrnridin06
March 3rd, 2008 12:36 PM
1978 Chevrolet C10 half ton horn contact/ horn wiringI have a 1978 Chevrolet C10 that it's horn does
isaac_22
December 26th, 2007 9:23 PM
