Venture 1997-2005
Platform: U-Body
front brake caliper bolts, what is the difference between top and bottom bolt?
Old July 8th, 2009 | 10:14 PM
avoyager's Avatar
Default front brake caliper bolts, what is the difference between top and bottom bolt?
I'm changing the front brake pads on my 2003 venture and didn't notice a difference between the top and bottom caliper bolts until I started reassembling.
One bolt has a small rubber/plastic tip; the other doesn't.
The rubber/plastic tipped one is round; the other has flats.
They both seem to fit interchangeably.
Anyone know why they are different and which goes on top?
Thanks,
Chris
Old July 10th, 2009 | 8:46 PM
avoyager's Avatar
I found out that the caliper bolt (pin) with the small plastic bushing on the tip should be installed on the bottom of the caliper. The other pin, the one w/the flats, should be installed on the top.
Old August 4th, 2013 | 2:00 PM
darling1s's Avatar
Default caliper bolts
I know this thread is old and you will probably never see this but thanks a million for posting the answer to your own question. I did the same thing (actually replacing the pins because one was sticking). I only have one jack and a couple stands so you just saved me having to try and tear apart the other side to figure out which one goes on the top.
finally03gt
September 15th, 2014 10:27 AM
factorypilot
July 22nd, 2013 2:45 PM
shawnmid
August 4th, 2010 2:19 AM
cbr600rrnut
November 24th, 2008 1:15 PM
waltd140
August 30th, 2007 12:31 PM
