Venture 1997-2005
Platform: U-Body
horn fuse replacement
Old Oct 24, 2008 | 6:49 PM
mdjbhouse's Avatar
Default horn fuse replacement
The horn stopped working on our 2002 Venture a while back after my wife kept repeatedly blowing the horn when she was in a celebratory mood (and no it had nothing to do with getting rid of me). At any rate I need to have it working again (daughter's drivers test coming up).
So I see there is a fuse or relay? under the hood.
My plan is to replace it and see if that is the fix but my initial attempt to wiggle it free didn't seem to work.
So my question is to replace the fuse I just wiggle it out with more force than I was using I guess?
Old Oct 24, 2008 | 7:06 PM
shawnvw's Avatar
Banned
Default RE: horn fuse replacement
use a pair of pliers to pull it out. they can get stuck sometimes
Old Oct 24, 2008 | 10:00 PM
mdjbhouse's Avatar
ok thanks I'll give er another go tomorrow.
Old Nov 2, 2008 | 1:51 PM
mdjbhouse's Avatar
Maybe I should start a new thread but, well, I'm not.
Don't think it's the fuse as I ended up swapping it with the A/C one which matched size and no difference plus A/C still works.
So my next question is where is the horn? I was going to do as a guy suggested and run a wire from the + terminal to see if it worked that way.
Old Nov 2, 2008 | 7:07 PM
shawnvw's Avatar
Banned
(1)
Horn-Left
The right one is in same position but on the rght side
Old Nov 3, 2008 | 7:40 PM
mdjbhouse's Avatar
Thanks for the pic.
ill4na8na2
Apr 7, 2024 6:50 PM
isaac_22
Dec 26, 2007 9:23 PM
Mercpuman
Jul 11, 2007 12:03 AM
waltd140
Jun 30, 2007 6:49 AM
zulu
Mar 28, 2007 4:58 AM
