Venture 1997-2005
Platform: U-Body
Instument panel lights 1999 Venture
Old Feb 14, 2007 | 7:40 PM
book1011's Avatar
Default Instument panel lights 1999 Venture
How do I replace the bulbs for the instrument panel on a 1999 Chevy Venture?
Old Feb 15, 2007 | 4:18 AM
shnormo's Avatar
Default RE: Instument panel lights 1999 Venture
Take the bottom pannel off from under the steering colum. This will reval a couple more screws holding in the top piece. There is a screw at the top center of the gauges (on the bezel) and that has to come off. Pull that a little bit foward and disconnect any switches attatched to the dash bezel. After that there are a few screws holding in the gauges. Pop them out, put your steering wheel at the lowest setting and then tilt the bottom out first and then disconnect the harness then pull the rest of it out. The bulbs will just screw out and then you should buy a bulb with the base from the dealer unless you feel like pulling up on the tabs for the bulb to get the old one out, put the new bulb in and then put the tabs back in.
buckmontana
Oct 15, 2022 6:21 PM
moejean
Nov 6, 2013 9:24 PM
195zx
Feb 15, 2008 10:34 AM
book1011
Feb 15, 2007 4:01 PM
acer33
Jan 4, 2007 6:42 PM
