Location of PCV Valve hose in the back
did lots of work and the hose to the pcv crumbled. Does it connect underneath the bracket that has all the spark plug wires in the middle of the engine in the back towards the firewall? There is a bracket with two bolts and the plug wires go into it and in looking at some graphs it appears perhaps there are two sideways nipples that the PCV hose connects in the middle and some other emissions hose below that. If yes can I attach without taking the bracket off or what do you recommend?
