Venture 1997-2005
Platform: U-Body
MAP Sensor Intermittant Low voltage
Old Apr 1, 2017 | 12:10 AM
SmithML's Avatar
Default MAP Sensor Intermittant Low voltage
Replace the MAP Sensor and still get rough running and dying at idle after the engine is warmed up. Where are the ground locations that I should check, and clean?
Old Aug 1, 2017 | 8:32 PM
02silverventure's Avatar
Did u ever figure out your issue?
Old Oct 23, 2017 | 1:03 PM
markfothebeast's Avatar
The ground is in the PCM. The + may have a poor connection in that maze of wiring harnesses. I continue to find broken wiring in mine till this day.
