OIL IN OVERFLOW...INTAKE GASKET?
I have a 98 Chevy Venture and heard nightmares about the intake gaskets and headgaskets going bad. My heat sensor in the car doesn't work either. I have notice I have to add coolant all the time and there is either oil or dirty coolant inside. This is a 3.4 engine. Do I need to replace the intake gaskets? I have replaced the water pump already. If I have to replace the intake gasket, how hard is this? What are the torque specs? Any tips?
Jason
Jason
i had what appeared to be oil in my coolant resovoir for the 3.4l but it turns out it was mold that grew inside that looked like oil, you might have the same problem, i ended up having to flush the cooling sytem b/c it was so black from this mold
flash12
December 23rd, 2008 10:13 AM
gulfcoastjoe
May 4th, 2008 12:38 PM
