Venture 1997-2005
Platform: U-Body
Random Multiple Misfire
Old Oct 1, 2009 | 9:02 AM
sekeraksm's Avatar
Default Random Multiple Misfire
Here is the story. I changed the plugs a few weeks ago and of course #3 (middle back) stripped out. I went and got a heli coil kit from car quest. I had to tap out the like 15 times before I got it. used the medium insert and put it in as far as it would go. It goes in all but the first row of tangs. Everything ran fine for 2 days now I get random multiple misfires, truck runs like crap and shudders also it drinks gas like you wouldnt believe. Do you think that #3 has something to do with it? Ive been reading that that problem is probably a vacuum issue and rarely a plug and wire issue. I have looked for a vacuum leak but everything looks attached. imposable to remove the egr valve to check it. One other thing, the wife overheated it a month ago, if that helps.
Old Feb 26, 2010 | 11:25 PM
mikeross's Avatar
The overheating might have been a big factor why the misfires happen. I noticed that on my car before and the mechanic told me that overheating is one of the causes and i had to replace the EGR valve.
buddyleno
Mar 31, 2017 8:13 AM
Davidsednothing
Dec 6, 2014 9:23 PM
jostov7
Aug 27, 2012 8:13 AM
Stickman
Mar 10, 2011 6:52 AM
02HEAVYDUTY
Nov 19, 2007 4:41 PM
