Venture 1997-2005
Platform: U-Body
Tail light/turn signal question
Old Aug 13, 2006 | 7:56 PM
neoncrazy101's Avatar
Default Tail light/turn signal question
Hey i dont know if this is a common problem among the Venture/Montana's but I have a friend who has a 2000 Pontiac Montana and the tail lights and turn signal have a slight problem and here it is.... when u turn on the drive side turn signal... both of them go on and the driver side tail light goes out if you hit the brakes while the turn signal is on...and when u hit the brakes i can see the driver side turn signal turn on just ever so slighty... what could be the problem? they said that its happened ever since like 2002 or so.
Old Oct 23, 2006 | 1:04 PM
golfer's Avatar
Default RE: Tail light/turn signal question
Is there a trailer wire harness installed ??
Old Oct 23, 2006 | 8:35 PM
yay someone finally responded lol...it does have the trailer hitch... i dont know if it has the wiring on it though...most likely will but it could be like them Land Rovers...
Old Oct 24, 2006 | 12:26 PM
golfer's Avatar
Well it would probably be a start by disconnecting the trailer harness to see if that's causing the problem.
Old Dec 11, 2006 | 5:51 PM
cajzmere's Avatar
GM has had major problems with this, there is a "Technical Service Bulletin" (TSB) on this at the dealership. Involves replacing one or both rear taillights if bad and fixing grounding wire on drivers side near the rear of van. This involved Chevy ventures from at least '98 on. Good Luck.
fishingpro77
HHR
Aug 4, 2016 12:44 AM
fraser jim
Feb 15, 2012 11:23 PM
RomanGuzi
Oct 2, 2011 11:40 AM
beckya99
Jul 12, 2011 12:29 PM
NoBrakes
Apr 15, 2009 6:14 PM
