Venture 1997-2005
Platform: U-Body
Trans issue. please help!
Old Aug 8, 2015 | 11:45 AM
gearhead2215's Avatar
Default Trans issue. please help!
99 venture 4t65e. Initially I blew a PCM fuse. After I replaced fuse, van went into limp mode with a TCC PWM DTC. Found a blown TCC fuse, replaced it. Van is now out of limp mode, but will not shift past 1st gear. No DTC's present. I can't seen to find any issue, and have traced all wires.
Old Aug 9, 2015 | 12:50 AM
sergeimoskva's Avatar
Hi !
A common problem with the 4T65E auto transaxle is the pressure control solenoid (PCS) causing the hard shifting and in most cases upshifts only. If this is the case with yours then a scan with a trans capable scan tool may reveal a stored DTC of P1811 (max adapt, long shift) which would confirm the PCS is suspect.
You have shown the error codes?
Old Aug 9, 2015 | 1:16 PM
The only DTC that came up was p0742 (TCC PWM), which turned out to be a blown TCC fuse. Now no codes present, and only 1st gear.
Old Aug 10, 2015 | 1:01 PM
Hi!
P0742 (TCC Stuck On/Fail TCC Solenoid)
At first check the connector on the PCM (wire white and yellow)
The most likely cause of the various conditions may be chips or debris
You can try to clear (replacement of the filter and pour DEXRON VI ), or replacement of the solenoid valve (TCC Solenoid)
williezoom
Jul 1, 2013 7:11 PM
Unknown1329
Feb 29, 2012 3:51 PM
