Venture 1997-2005
Platform: U-Body
Venture twin Montana whcih AC Delco plugs?
Old Oct 23, 2011 | 6:58 PM
bighank's Avatar
Default Venture twin Montana whcih AC Delco plugs?
Several forums say use AC Delco plugs to prevent misfiring etc. 2 AC Delco plugs listed. AC 14 regular Rapidfire plug and the AC 41-940 Professional Platinium. The AC 14 plugs are heat range 3 and the AC 41-940 plugs are heat range 4. I guess the 41-940 are hotter.
Engine not burning oil (leaking some). Which ones should I get? Car has 90 K miles and is 12 years old (1999).
Old Oct 26, 2011 | 4:29 PM
bighank's Avatar
Default OEM Plugs are 41-940
New plugs are gapped at .50 not .60 as specified. They are double platinium. Supposedly should not regap.
Should I gap them to .60?
Old Oct 26, 2011 | 5:32 PM
EinST's Avatar
Where did you get those plugs and where were they made? There shouldn't be any need to gap them but you can if it makes you sleep better. Just try not to rub on the center electrode. Or, get NGK Platinum plugs.
texasflyfisher
Sep 25, 2010 2:02 PM
compguy
Feb 6, 2010 11:13 PM
jdmae86
Jan 8, 2009 10:18 PM
dbrog28301
Colorado
May 21, 2007 9:48 PM
