Venture 1997-2005
Platform: U-Body
Wipers aren't parking
Old Nov 17, 2021 | 10:43 AM
Photon440's Avatar
Default Wipers aren't parking
Working perfectly normal until last weekend, I went to turn off my front wipers and instead of parking down low, they come to a stop at the opposite end of the cycle - both wipers stay up at each end of the windshield. Otherwise they work normally; both high and low speeds and intermittent operations are fine. It's just that they no longer drop down below the hood when turned off.
Is there a switch that could have moved? Is it internal to the wiper motor itself?
This is on a 2003 Montana - same as the Venture but there isn't much action over on the Pontiac forum so I thought I'd ask here.
Thanks for any advice.
Old Nov 18, 2021 | 2:14 PM
ventureguy's Avatar
The Wiper Control box controls the parking. Its a black box by the wiper motor. The same box is on the Venture.
Old Nov 26, 2021 | 4:54 PM
Photon440's Avatar
Okay, it's working now. Pulling off the long plastic cover over the mechanism, I sprayed lube (fluid film) over the rotating assembly directly over the wiper motor, tapped it a couple of times with a block of wood, (didn't want to hurt anything with a hammer) and it started functioning as it should. I'd read about this elsewhere, gave it a try and was happy to see it succeed.
Jennifer Gaines
Apr 15, 2021 9:02 PM
mike28
21
Mar 7, 2013 3:54 PM
2/28/09
Dec 14, 2010 3:27 PM
03rubicon
Jun 15, 2010 6:11 PM
Shaun_95
Oct 20, 2009 10:17 AM
