Volt Get plugged into Chevrolet's electric car! The batteries will take you most anywhere and the on-board generator can take you beyond!
Named the 2011 North American Car of the Year
Chevrolet Volt
Heater-how do they work??.
Old Dec 23, 2010 | 12:07 AM
Terry Neff's Avatar
Question Heater-how do they work??.
Just being curious.I wouldn't think the Volt has much of a cooling system if,and again I don't know,one at all.So how does the heaters work??.Do they work that well??.If your running off the battery,where does the heat come from??.
Old Dec 23, 2010 | 12:50 AM
2wd-K5's Avatar
a ceramic heater i would imagine, it cant be a coolant based system
Old Dec 23, 2010 | 9:16 PM
Terry Neff's Avatar
Question
I am a how does it work kind of guy.So I did a search on Google.Which answered and added to the confusion on my part.From what I read it does have a coolant rad that has three sections.One section that is Dex-cool for the 1.8 gas engine(makes sense),one section of the rad for cooling the batteries(didn't know batteries had to be cooled,huh??),and the third section for the drive system,(I think it said it too the Dex-cool,strange).It said the coolant was diverted by a valve weither it be on battery power or by the gas engine to a heater core.I wouldn't think the battery side would be that hot.In fact given the size of the gas engine it too I wouldn't think would generate that much heat to the heater core.Then there was something about A/C equipped models where on battery power it cut down on the range by 1/3.A/C powered???.
Well I hope someone will chime in with some experience or factory training to clear up some of the confusion on my and who knows other guys.
Old Dec 24, 2010 | 1:45 AM
2wd-K5's Avatar
ahh that makes a lil sense, it has a 3 part cooling system the cooling for the drive system (electric motors) the batt packs and the IC engine, the batteries get hot as they are being used, and the batteries have a really intricate cooling system for them to prevent overheating. one thing i forgot about is the engine starts at the first start of the day if it is not plugged in to warm the batteries.
Old Dec 24, 2010 | 5:30 AM
Terry Neff's Avatar
Thanks for partaking in your replies.As I said,any master Chevy Tech's out there with factory training want to chime in???.
Old Jan 29, 2011 | 7:13 PM
Davidjones's Avatar
hey i too wanted to know if it had one
thanks for helping me out guys
Old Feb 1, 2011 | 8:32 AM
janishjann's Avatar
Banned
Hey its nice description how it works.. Thanks for sharing and helped me..
Old Dec 15, 2011 | 12:05 PM
SabrToothSqrl's Avatar
Default heater
google 'heat pump'
that's what it would use for the passenger cabin. (I assume).
Old Dec 17, 2011 | 2:50 PM
I don't know but heat pump would also been my guess...
Old Jul 1, 2012 | 3:11 AM
Sandello's Avatar
There are electrical metal-heater in Volt.
Check it out:
Chevrolet 2012, Volt, Front end sheet metal-heater-vehicle maintenance, 2011-2012 * R HOSES & PIPES/HEATER PART 2 SHUTOFF VALVE TO HEATER * (1R08-006)
Heater module is connected with radiator and engine through pump.
Heater module is connected with inside radiator by 2 tubes. You can see it here #23:
Chevrolet 2012, Volt, Body mounting-air conditioning-audio/entertainment, 2011-2012 * R A/C & HEATER MODULE ASM * (1R09-004)
