No power steering/brakes at idle
New User
Awaiting E-mail Confirmation
Hey folks,
New to the site. Having a lot of trouble with a new power steering pump and high pressure line installation.
1995 Astro AWD w/hydroboost. Reman pump from NAPA.
Got the new pump in and everything is hooked up, no leaks, ect, got the system bleed best I could, but no power steering/brake assist at idle. Rev it up a little and everything comes to life.
Cannot drive as is. I even loosened both the high pressure fitting at the master cylinder, let it bleed out, tighten, then loosened the low pressure fitting at the gear box, let it bleed out, tightened, all while motor was running and continuing to fill reservoir. I'm at a loss at this point. I have dumped prolly a gallon of PS fluid on my driveway. lol
Any thoughts?
Any thoughts?
Is your idle speed set too low? It appears it might be too low because everything starts to work when you rev it up a bit. Did you use the same pulley on the power steering pump or did you get a new one? Are there any vacuum leaks?
New User
Idle speed was never touched and appears fine. Same pulley yes, and no vacuum leaks. Its almost as if there isn't enough hydrolic pressure at idle.. Is there a way to test if the pumps hydrolic pressure is sufficient at low RPM; without a spendy pressure tester of course?
Blaine B.
Express & G-Series Vans
12
April 2nd, 2015 12:00 PM
buddho
Silverado & Fullsize Pick-ups
February 5th, 2015 9:52 PM
dcommons
February 27th, 2011 9:22 PM
