Astro 1985-2005
Platform: M-Body
No power steering/brakes at idle
Old Jul 14, 2012 | 11:17 AM
_brad_'s Avatar
New User
Awaiting E-mail Confirmation
Unhappy No power steering/brakes at idle
Hey folks,
New to the site. Having a lot of trouble with a new power steering pump and high pressure line installation.
1995 Astro AWD w/hydroboost. Reman pump from NAPA.
Got the new pump in and everything is hooked up, no leaks, ect, got the system bleed best I could, but no power steering/brake assist at idle. Rev it up a little and everything comes to life.
Cannot drive as is. I even loosened both the high pressure fitting at the master cylinder, let it bleed out, tighten, then loosened the low pressure fitting at the gear box, let it bleed out, tightened, all while motor was running and continuing to fill reservoir. I'm at a loss at this point. I have dumped prolly a gallon of PS fluid on my driveway. lol
Any thoughts?
Old Jul 14, 2012 | 12:17 PM
Is your idle speed set too low? It appears it might be too low because everything starts to work when you rev it up a bit. Did you use the same pulley on the power steering pump or did you get a new one? Are there any vacuum leaks?
Old Jul 14, 2012 | 12:36 PM
_brad_'s Avatar
New User
Idle speed was never touched and appears fine. Same pulley yes, and no vacuum leaks. Its almost as if there isn't enough hydrolic pressure at idle.. Is there a way to test if the pumps hydrolic pressure is sufficient at low RPM; without a spendy pressure tester of course?
Old Jul 14, 2012 | 2:04 PM
kevinkpk's Avatar
Thats a grotor pump. If it is low at idle, it probably is a bad pump. Is there a relief valve on the system?
Blaine B.
12
Apr 2, 2015 12:00 PM
buddho
Feb 5, 2015 9:52 PM
dcommons
Feb 27, 2011 9:22 PM
HeatDet
Astro
15
Jun 9, 2010 9:18 PM
pinadenisse
Astro
Sep 24, 2009 6:49 AM
