Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
high beams don't work
Old April 7th, 2009, 7:51 PM
iowaman0322's Avatar
Default high beams don't work
how can i find out why my high beams don't work. when i pull back on the lever it doesn't do anything. sometimes one of the turn signals will turn on.
Old April 7th, 2009, 10:24 PM
EvansBlue's Avatar
It sounds like a bad multifunction switch.
Old April 8th, 2009, 4:17 PM
is that the column switch
Old April 8th, 2009, 4:44 PM
do you know if i could bypass the switch and just hook it up to a toggle switch
Old April 9th, 2009, 11:47 PM
EvansBlue's Avatar
You really need to replace the MF switch. I don't recommend bypassing it.
Old April 2nd, 2010, 3:50 PM
heisabud's Avatar
I had the same problem, the switch stopped working completely, but after I had the ignition cylinder replaces,, the mechanic also seemed to repaire the switch.
Old October 11th, 2010, 3:22 PM
2short's Avatar
so...if i have tilt steering....but do not care for the cruise control... am i able to replace the lever and switch with non tilt parts....same year and make?
NoBrakes
Silverado & Fullsize Pick-ups
October 15th, 2017 4:38 AM
Aaron Green
Cobalt
March 15th, 2015 9:21 PM
jroldsch
August 25th, 2010 2:26 PM
rla223
August 18th, 2009 6:35 PM
jgazette
December 31st, 2007 6:36 AM
Quick Reply: high beams don't work
