Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
high beams don't work
Old Apr 7, 2009 | 7:51 PM
iowaman0322's Avatar
Default high beams don't work
how can i find out why my high beams don't work. when i pull back on the lever it doesn't do anything. sometimes one of the turn signals will turn on.
Old Apr 7, 2009 | 10:24 PM
EvansBlue's Avatar
It sounds like a bad multifunction switch.
Old Apr 8, 2009 | 4:17 PM
is that the column switch
Old Apr 8, 2009 | 4:44 PM
do you know if i could bypass the switch and just hook it up to a toggle switch
Old Apr 9, 2009 | 11:47 PM
EvansBlue's Avatar
You really need to replace the MF switch. I don't recommend bypassing it.
Old Apr 2, 2010 | 3:50 PM
heisabud's Avatar
I had the same problem, the switch stopped working completely, but after I had the ignition cylinder replaces,, the mechanic also seemed to repaire the switch.
Old Oct 11, 2010 | 3:22 PM
2short's Avatar
so...if i have tilt steering....but do not care for the cruise control... am i able to replace the lever and switch with non tilt parts....same year and make?
NoBrakes
Oct 15, 2017 4:38 AM
Aaron Green
Cobalt
Mar 15, 2015 9:21 PM
jroldsch
Aug 25, 2010 2:26 PM
rla223
Aug 18, 2009 6:35 PM
jgazette
Dec 31, 2007 6:36 AM
