Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
Strange turn signal problem
Old June 20th, 2006, 3:09 PM
dk
dk's Avatar
Default Strange turn signal problem
Hey everyone,
I have a 1994 Corsica (2.2L), and when I put the left turn signal on, it just stays lit. The right blinks fine. I've replaced both front and back bulbs. When I put on the hazards, both sides blink just fine. Could a faulty turn signal switch only cause one side to not work? And if it is, is that switch on the steering column or do I have to remove the steering wheel?
Thanks!
D
Old June 20th, 2006, 5:57 PM
beckeruti's Avatar
Default RE: Strange turn signal problem
usually if it comes on its not the switch that you turn on
its probably the turn signal flasher
which might be in near the fuses
can u flash it manually with the lever on the steering column
i dunno maybe
good luck
Old June 20th, 2006, 7:58 PM
dk
dk's Avatar
Yes, I can do it manually with the lever.
Old September 11th, 2006, 4:19 PM
jayno20's Avatar
i had that same problem with an 89 Z24 i had, it ended up being one of the bulbs was burnt out. so check all of them in the front and in the rear light fixture
Old September 11th, 2006, 9:13 PM
kcb37's Avatar
I would go with the light blub then the flasher. If it isn't either one how much will you spend on the flasher.
fishingpro77
HHR
August 4th, 2016 12:44 AM
RomanGuzi
October 2nd, 2011 11:40 AM
2006isuzu_i280
Colorado
December 13th, 2008 8:45 AM
two slow
Silverado & Fullsize Pick-ups
March 4th, 2008 11:03 AM
313hitman
March 6th, 2007 7:53 PM
Quick Reply: Strange turn signal problem
