Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
Strange turn signal problem
Old Jun 20, 2006 | 3:09 PM
dk's Avatar
dk
Default Strange turn signal problem
Hey everyone,
I have a 1994 Corsica (2.2L), and when I put the left turn signal on, it just stays lit. The right blinks fine. I've replaced both front and back bulbs. When I put on the hazards, both sides blink just fine. Could a faulty turn signal switch only cause one side to not work? And if it is, is that switch on the steering column or do I have to remove the steering wheel?
Thanks!
D
Old Jun 20, 2006 | 5:57 PM
beckeruti's Avatar
Default RE: Strange turn signal problem
usually if it comes on its not the switch that you turn on
its probably the turn signal flasher
which might be in near the fuses
can u flash it manually with the lever on the steering column
i dunno maybe
good luck
Old Jun 20, 2006 | 7:58 PM
dk's Avatar
dk
Yes, I can do it manually with the lever.
Old Sep 11, 2006 | 4:19 PM
jayno20's Avatar
i had that same problem with an 89 Z24 i had, it ended up being one of the bulbs was burnt out. so check all of them in the front and in the rear light fixture
Old Sep 11, 2006 | 9:13 PM
kcb37's Avatar
I would go with the light blub then the flasher. If it isn't either one how much will you spend on the flasher.
fishingpro77
HHR
Aug 4, 2016 12:44 AM
RomanGuzi
Oct 2, 2011 11:40 AM
2006isuzu_i280
Colorado
Dec 13, 2008 8:45 AM
two slow
Mar 4, 2008 11:03 AM
313hitman
Mar 6, 2007 7:53 PM
