gas cap gets hot
gas cap gets hot
I need some help. Just put a new/used motor in My 91 camaro and I got it running only cant seem to get the timing right even though its timed at 0 and found out my gas cap get very hot. Never heard of this before any ideas? Thanks
Ok so I put a 1984 305 in my 1991, I took all of the accessories alternator water pump ect. I also put my maifold and tbi and distributor which is a standard distributor but cant seem to keep it running
If it dies as soon as the key goes from Start to Run, then most likely a wiring problem. A standard distributor gets a full 12V during starting and a reduced voltage when running to reduce point wear.
If that's not what's happening, then might be lack of gas. Check fuel pressure w/ key on, engine off and during starting.
