2016 Camaro
Platform: F-Body & Zeta.
gas cap gets hot
Old Jul 14, 2014 | 1:56 AM
kdracomayo's Avatar
Default gas cap gets hot
I need some help. Just put a new/used motor in My 91 camaro and I got it running only cant seem to get the timing right even though its timed at 0 and found out my gas cap get very hot. Never heard of this before any ideas? Thanks
Old Jul 14, 2014 | 8:51 AM
sledge.impy's Avatar
Did the interwebs help any?
http://www.google.com/search?q=91+camaro+timing
Old Jul 14, 2014 | 7:26 PM
kdracomayo: Welcome to the forum.
Old Jul 14, 2014 | 11:14 PM
kdracomayo's Avatar
Does the size of the distributor matter? The one that came with the motor is much bigger round than the one I put on
Old Jul 15, 2014 | 12:13 AM
Sounds like it came with a HEI distributor and you put in a standard one. I believe your '91 would have come with a HEI distributor.
Old Jul 15, 2014 | 5:19 PM
kdracomayo's Avatar
Ok so I put a 1984 305 in my 1991, I took all of the accessories alternator water pump ect. I also put my maifold and tbi and distributor which is a standard distributor but cant seem to keep it running
Old Jul 15, 2014 | 6:38 PM
Does it start and run at all?
Old Jul 15, 2014 | 10:30 PM
kdracomayo's Avatar
It will start but wont stay running
Old Jul 16, 2014 | 9:11 PM
If it dies as soon as the key goes from Start to Run, then most likely a wiring problem. A standard distributor gets a full 12V during starting and a reduced voltage when running to reduce point wear.
If that's not what's happening, then might be lack of gas. Check fuel pressure w/ key on, engine off and during starting.
Old Jul 18, 2014 | 10:18 AM
Ragnar's Avatar
These cars were using computers back then, not as easy to swap different things around. I would check into that.
