removal of passenger front door panel from 96 caprice
I need to replace passenger side mirror assembly. How do I remove the door panel and reconnect the mirror? What tools will I need to do this?
a philips screwdriver, socket wrench, start with the screws on arm rest and door handle, then pop door panel off around edges, mirror should be easy to access, find socket size, mirror will have a clip for the wiring to undo, undo that, replace w/new mirror, connect the electrical clip, then re assemble door how you took it apart.
dubbs900
October 12th, 2014 2:42 PM
EvansBlue
S10 & Blazer DIY and Useful Threads
August 4th, 2009 12:20 AM
LeoDuffrin
April 27th, 2006 10:43 PM
