Platform: J-body
1997 Cavalier wont start
Old Sep 14, 2012 | 4:08 PM
Kilokk's Avatar
Default 1997 Cavalier wont start
I am having a problem with my 1997 Cavalier RS 2.2l automatic (3 gear I am pretty sure). I can't get the thing to start. I have tried a new battery, new starter solenoid (starter works fine. My father drives a 99 sunfire so I have been using that as a control to check my parts such as my starter), I changed the ignition switch, and even the starter relay. I'm pretty muc at my wits end with this thing and I was hoping someone here would be able to help.
If I didn't list enough information just let me know and I will get you whatever you need to help me. Thanks for your time.
Old Sep 14, 2012 | 4:30 PM
kevinkpk's Avatar
So, it cranks, dosen't crank? Cranks but won't start?
Old Sep 14, 2012 | 5:51 PM
Kilokk's Avatar
Sorry I didn't put that in the first post, I'm new to all of this (first time really working on a car). It won't crank.
Old Sep 14, 2012 | 6:43 PM
kevinkpk's Avatar
With the key switch on, do you have lights/dash guages ect.? If so, I'd suggest either putting it in nuetral or holding the gear shift hard in park. Could be a nuetral saftey switch.
Old Sep 14, 2012 | 8:56 PM
Kilokk's Avatar
Yeah everything is working, the car just won't start. That's what we were thinking. Might pull the one off of my fathers to see if that's it. Any way to bypass that until I can replace it if that ends up being the issue?
Old Sep 15, 2012 | 7:54 AM
kevinkpk's Avatar
You'd have to locate the switch, and jumper it out, close the contacts in other words. That is what it is a nuetral "saftey" switch. If you jumper it out it (if thats the problem) start with it in gear.
Df0927
Dec 23, 2013 4:18 PM
perry2326
Oct 19, 2013 10:25 PM
gnrrunner
Jan 29, 2011 7:21 PM
pro_51492
Jan 29, 2010 11:41 AM
aream2000
Jan 16, 2010 9:01 AM
