Platform: J-body
95 cavalier 2.2 problems
Old Feb 23, 2011 | 9:36 PM
shawtpop74's Avatar
Default 95 cavalier 2.2 problems
having a problem with my 95 cavalier. fuel pump wont pump unless you trick it. and still after that i have no pulse i the injectors.can spray fuel in the throttle body and it will crank
Old Mar 4, 2011 | 11:04 PM
dakota1820's Avatar
explain trick it. maybe a failing fuel pump?
Old Mar 6, 2011 | 6:22 PM
shawtpop74's Avatar
Default trick the fuel pump
where the fuel pump relays are under the the hood. you stick a wire on the hot side of the relay and jump it to the ground side of the relay.
Old Mar 6, 2011 | 8:30 PM
dakota1820's Avatar
gotcha never heard that term before. i would check the wiring and check anything wired in. im not sure how they have it wired. but if you follow the wires you will probably figure all that out and the problem
Old Mar 17, 2011 | 4:28 PM
dtsman's Avatar
Then it's probably the relay.?
Old Mar 31, 2011 | 8:39 PM
shawtpop74's Avatar
Default 2.2
think the problem was the ecm. bought the new one from advance auto. but know i have a new problem. DIDNT GET THE PRPOM-CHIP OUT THE OLD COMPUTER.any advice.
Mom2ThreeACG
Traverse
Mar 12, 2018 6:20 PM
mwehrste
Dec 29, 2014 11:19 AM
Toddbrandon28
Sep 26, 2014 7:26 AM
perry2326
Oct 19, 2013 10:25 PM
atomheartmother
Jun 29, 2008 9:41 AM
