Platform: J-body
2001 Cavalier Emergency Brake
Old Dec 9, 2012 | 5:30 PM
wjsdunning's Avatar
Default 2001 Cavalier Emergency Brake
I cannot find an adjustment for my 2001 cavalier emergency brake. I have adjusted the rear drums and they are good. I climbed under the car and could not find any adjusting nuts. I also looked inside the console and could not find anything.
Thanks for your help
Old Dec 9, 2012 | 9:20 PM
its suppose to be self adjusting. Apply and release it 6x.
Old Dec 11, 2012 | 10:16 PM
wjsdunning's Avatar
I have tried the brake adjustment but that is not the problem. The cable is stretched or something is worn. I am trying to adjust the cable but I starting to think that my only option is to replace the cable. I am hoping someone can give me an idea on how to take up the slack. It is not a lot . The brake works but you really have to pull hard on it
Old Dec 12, 2012 | 7:01 PM
the only manual adjustment you can do is at the drum brake star wheel. If that is set up with to much clearance you will also have a deep pedal at the service brake.
If that is set up correctly and you still have no ebrake; yep...cables or e-brake lever assembly.
Old Dec 12, 2012 | 7:19 PM
wjsdunning's Avatar
thanks
bkordrs
May 15, 2011 11:05 AM
rolemac
Jun 7, 2009 3:27 AM
jrg777
Dec 9, 2008 6:21 PM
diane888
Aug 5, 2007 9:46 PM
LouisT
Nov 13, 2006 6:54 PM
