Platform: J-body
4T40E Transmission Problem
Old March 23rd, 2014, 11:37 AM
saada3's Avatar
Default 4T40E Transmission Problem
Hi
I have a Cavalier 1996 2.2 4 gears.
I have a glitch that occurs from time to time, can happen week other day ... there is really no specific time.
Also fault occurs not turn on lamp malfunction.
The problem is such that when I cruise at 60 mph the rpm is at 2500 instead of 2000 + -, in this situation you can not fix the cruise control. When rpm Normally relative speed cruise control works, during all this time there is no lamp to malfunction.
After consulting with several machinists Most say that one Hslonoad invalid, do not ever work here.
The question which one to faulty and do ever you have any such a problem?
* Please mention that I changed twice oil and filter.
Old March 23rd, 2014, 8:54 PM
Segfault's Avatar
Very little information. From what you posted I'd say there may be a ground problem.
Old March 23rd, 2014, 11:21 PM
translator please.
Old March 24th, 2014, 1:42 PM
saada3's Avatar
I do not have too much information ...
When I'm at a constant speed, rpm does not match the speed.
Change is 500 rpm above should be.
Probably one of Solenoid not opening or closing passage oil.
The question is which one?
There are other missing information that could help?
Old March 25th, 2014, 1:47 AM
saada3's Avatar
http://www.justanswer.com/oldsmobile...rive-2600.html
Coravir
Silverado & Fullsize Pick-ups
October 26th, 2019 3:28 PM
Gregg
August 4th, 2015 9:08 AM
Fishnchipy
December 24th, 2014 1:56 PM
DSGB
May 29th, 2013 8:54 AM
falconowner90
July 16th, 2010 5:19 PM
Quick Reply: 4T40E Transmission Problem
