Platform: J-body
97 cav abs/ brake light on
Old Nov 19, 2012 | 4:46 PM
comet424's Avatar
Default 97 cav abs/ brake light on
hi i trying to get my 97 ready to be certified but abs and brake light on
i have bleed system many times i even replaced the master cylinder unit from a 97 sunfire i have light still on
i even bought 2 front abs sensors and 2 rear hubs and plugged them in but didnt install them as i dont wanan replace if i dont need it
but ligths still so what is the reason?
Old Nov 19, 2012 | 5:39 PM
comet424's Avatar
also i have swapped out the 2 fuses and the relay on top of what i tried above
Old Nov 19, 2012 | 11:53 PM
Camaro 69's Avatar
Site Ambassador
Check to see if your 3rd brake light is out. 4th gen Camaros will trip the ABS and brake light when the 3rd brake light is out, wouldn't surprise me if other models work this way as well.
Old Nov 20, 2012 | 6:09 AM
comet424's Avatar
ok i looked but all lights work fine any other suggestions
Old Nov 24, 2012 | 7:50 AM
get the chassis code read and post the results here. That is your diagnostic starting point.
a dyi basic code reader won't read chassis codes. You will need a full function scan tool.
Old Nov 25, 2012 | 11:18 AM
comet424's Avatar
ah ok ill find out i sending in car to be certified on tuesday so ill find out
as i cant read the codes so they will have to also checked the wires cnat find no breaks
and you cant read any voltage continuity or ohms on any abs plug so you cant test any broken lines so that sucks
i could care less i should have just taken cluster out and put electrical tape over the 2 brake lights so i wouldnt have to as if you can drive a car that has no abs or what not you shouldnt be driving at all cant relie on abs to stop you
Old Nov 26, 2012 | 5:51 PM
you can ohms abs wires. its part of pinpoint testing; the ebcm and sensor connectors are disconnected first. maybe your thinking airbag systems.
hope your in a region that allow it to pass safety inspection with an abs light on.
Old Nov 27, 2012 | 5:13 AM
comet424's Avatar
ya i not sure i sent it in last night to local garage maybe he let it pass like its just dumb
no have not tested the airbage
all i did was unhook each sensor the 4 sensors and just put multi meter at each connector the 2 and i couldnt get nothing and i never unhooked abs wires at other end so i gave up i not sure where they plug into
i dont know if they go in the computer as the Hayes repair book will not show abs wiring diagrams
Old Dec 10, 2012 | 11:52 AM
comet424's Avatar
hi latest update and i still pissed
i have the abs light on i thought it was sensors it wasnt i though air and it wasnt i bled them etc
car is now at the garage for 2 weeks and all mechanic says is his code reader says can not communicate with the ABS computer so is there another computer i can pull out of my 97 sunfire and give him to put in there to try it or does it go directly to the computer ??? or how does this work
as really i dont see reason u need ABS to pass certification cuz brakes work normal as they arent going to put ABS on older vehicles so there no point i should have put black tape over the abs and brake light ugh
and does anyone know the wires to check if there is a break?
kaptain howdie
Dec 16, 2014 8:20 PM
ericmckinney
Uplander
Oct 14, 2011 10:35 PM
Bulldog9539@gmail.com
Sep 4, 2011 1:54 AM
Deteoni
Mar 28, 2009 1:39 PM
tannerthehammer
Apr 2, 2008 1:11 AM
