Platform: J-body
98 Cavalier Stall / Stays running
Old June 22nd, 2013, 3:49 PM
Jaeaey58's Avatar
Default 98 Cavalier Stall / Stays running
Well i am back yet again with the same car. 98 Cavalier 2.2L. It cranks ok, little bit of a rough idle. it wants to die but then it idles up and is ok for a few, then rinse and repeat. it will do that untill u turn it off, if u try to drop it in gear it dies just about automatically. Also, it has been wanting to stay running after you turn the ignition off. i have done research and that could b the igniton switch. I am on a very tight budget and need this car to get to and from work, i have nobody that has a fuel pressure gauge, and it does not have the little test port on the fuel rail =[ Changed the plugs today, one had a huge crack in it. But to no avail it didnt help at all.
GameOva
May 19th, 2019 2:04 PM
MasterPonAtari
January 13th, 2015 9:54 PM
Mike San
December 29th, 2012 10:48 AM
efxr6wagon
November 19th, 2009 2:47 PM
m00n
March 6th, 2008 6:30 PM
Quick Reply: 98 Cavalier Stall / Stays running
